BT.com
Wishlist
Microlab M223U 2.1 Speaker set 17W RMS, SD, USB, FM Radio
Delivery
Standard Due date unavailable
Microlab M223U is a multiple-function speaker for your desktop audio. It is simple to operate and good for listening music. Plug in this system and boost your desktop music entertainment instantly.
Beautiful Looking Design
M223U applies a modern desgin concept for its cabinets. All the satellites and subwoofer are maden by using hi-end wooden materials.
Good sound performance
M223U has excellent audio qualtiy.The subwoofer is built in the bass reflex technology and the satellites give clean treble sound.
Built-in Useful functions
M223U is the perfect companion for expanding your desktop entertainment. It does not only integrate the music playing function, but also can read SD card and listening radio programmes. It also support USB flash disk reading.
Convenient operation system
M223U is easy to use. The front panel on the subwoofer cabinet houses the playback and master volume controls.. It is also very easy to connect with most media players through the standard audio cable.
Features:
  • Quality 2.1 subwoofer system with depth and full range audio performances
  • Powerful subwoofer and crystal clear satellites
  • Front panel with playback controls and volume level knob
  • Bass reflex design for efficient subwoofer performances
  • Made with quality sound handling materials for superb sound handling characteristics
  • Analog FM radio with telescopic antenna
  • USB type A and SD card slots for digital music playbacks
Microlab M-223U - speaker system
Speaker system - 2.1-channel
FM radio, USB host, SD card reader
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
17 Watt
Frequency Response
35 - 20000 Hz
Amplifier
Integrated
Supported Digital Audio Standards
WMA, MP3
Speaker System Details
1 x subwoofer 9 Watt 8 Ohm , 2 x satellite speaker 4 Watt 4 Ohm
3.2 kg
1 year warranty
Enclosure Colour
Speaker System
System Components
Speaker Type
Active
17 Watt
Frequency Response
35 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Total Harmonic Distortion
0.1%
Amplifier
Integrated
WMA, MP3
Speakers Included
1 x subwoofer - 9 Watt - 8 Ohm - wired , 2 x satellite speaker - 4 Watt - 4 Ohm - wired
Driver Details
Subwoofer: 1 x subwoofer driver - 4"
Driver Details (2nd speaker)
Satellite speaker: 1 x full-range driver - 2.5"
Connector Type
Audio line-in (RCA x 2)
3.5 mm to RCAx2 cable
Power Source
AC power adapter
3.2 kg
Dimensions (WxDxH) / Weight Details
Satellite speaker: 8.9 cm x 9.7 cm x 15.2 cm , Subwoofer: 15.5 cm x 28.5 cm x 24.2 cm
Limited warranty - 1 year
Scroll to top
