Click to visit BT.com
BT.com
Wishlist
Microlab FineCone FC360 - 5.1-channel PC multimedia speaker system - 100 Watt (Total)
5.0*
Quicklinx: 7ZH6WS00
Mfr#: MICROLABFC360-5.1
5.1 speakers system with powerful amplifier for your home theater
Enjoy movie audio effects from the comfort of your own home with 5 satellites and a subwoofer. This system places satellite speakers around your room and creates a dynamic surround effects with your movie sound production. Comes with remote control for convenience.
Features:
Powerful home theater 5.1 surround subwoofer system with full range acoustic production and surround satellites
6.5" woofer system for deep vocal and bass effects
All magnetically shielded for safe positioning near TV
Standalone amplifier with full front controls and includes wireless remote control
Technical Specifications:
Amplifier:
Output power: 100 Watt RMS
Power distribution: 14 Watt x 5 + 30 Watt
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 30Hz - 20kHz
Signal/Noise ratio: > 70dB
Separation: > 40dB
Input sensitivity: 380mV
Nominal impedance: 4 ohm
Speakers:
Tweeter driver type: 2.5"
Tweeter rated power: 14 Watt
Bass driver type: 6.5"
Bass rated power: 30 Watt
Frequency range: 30Hz - 20kHz
Interfaces:
Output: RCA sockets
Input: RCA sockets
Power:
Power supply: AC 220 - 240V, 50Hz, 380mA
Fuse: T800mAL250V
Includes Remote control
Package Contents:
FC360 5.1 subwoofer
FC360 5.1 amplifier
FC360 satellites x 4
FC360 center satellite
2RCA - 2RCA cables x 3
3.5mm stereo - 2RCA cable
Infrared remote control
User manual
Dimensions:
Subwoofer dimension: 255 x 255 x 287 mm
Satellites dimension: 88 x 200 x 102 mm
Center Satellites dimension: 230 x 88 x 102 mm
Amplifier dimension: 96 x 252 x 310 mm
Product net weight: 14.5 kg
Giftbox dimension: 500 x 373 x 398 mm
Giftbox gross weight: 15.4 kg
Export carton dimension: 512 x 385 x 416 mm
Export gross weight: 16.8 kg
Customer reviews
Write a review for the Microlab FineCone FC360 - 5.1-channel PC multimedia speaker system - 100 Watt (Total) here!
MC 360 5.1 channel speaker System
Reviewed by Anonymous Review Posted 03/09/2012
Pleasantly suprised at the clarity and output of these speakers . A stylish look and bags of power for streaming spotify through my Notebook or TV. Would recommend these to anyone and a great price
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Superb*
Reviewed by Keith. Review Posted 13/07/2013
This product is amazing. Looks, clarity and what a bargain.
I replaced this with an old Cambridge Soundworks system I had for 10 years(lol), so I thought time for a upgrade.
The subwoofer is pretty damn big, bigger than what I thought it was going to be and packs a nice punch, well enough to annoy the neighbors lol. The overall sound quality of this system is just perfect, and works great with anything, gaming, movies and music.
My one and only problem is the none of the small satellite speakers have mounting holes, so finding another to mount these on the wall is a bit of a pain.
All in all 10/10. especially if you're on a budget.
A must buy.
  • Overall 5*
  • Ease of use 5*
Superb*
This product is amazing. Looks, clarity and what a bargain. I replaced this with an old Cambridge Soundworks system I had for 10 years(lol), so I thought time for a upgrade. The subwoofer is pretty damn big, bigger than what I thought it was going to be and packs a nice punch, well enough to annoy the neighbors lol. The overall sound quality of this system is just perfect, and works great with anything, gaming, movies and music. My one and only problem is the none of the small satellite speakers have no mounting holes, so finding another to mount these on the wall is a bit of a pain. All in all 10/10. especially if you're on a budget. A must buy.
  • Overall 5*
  • Ease of use 5*
A fine set of speakers
Reviewed by Rob. Review Posted 24/10/2013
Finding a decent set of 5.1 speakers can be a difficult task, as many often sacrifice on quality for quantity. The FC360 5.1 however make a good compromise. In order to hook these up to my PC I had to purchase an additional two RCA to Phono cables, which was easily done. Over the past several months I've been extensively testing them with a range of games and music. The speaker's physical build seems to be solid, made from wood, which aids in producing a better sound, albeit the amp is slightly wobbly. Another concern was a low hissing just audible when nothing is being played, although this is something nearly every speaker system suffers from. I'm no audiophile but I find the acoustic range to be well represented. I'm especially fond of the deep bass which greatly adds to many a scenario. The provided remote is a boon allowing for precise adjustments on all six speakers. Overall, I would thoroughly recommend the FC360 for either a TV or PC, they'd make a great addition.
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
