BT.com
Wishlist
Metrologic VoyagerCG hand-held single sca
Metrologic VoyagerCG hand-held...
£98.20
13 in stock
£98.20
Add to wishlist
Delivery
Standard 1-3 working days
With a futuristic design and high-performance scanning system, Metrologic's MS9520 Voyager represents the best auto-triggered scanner value on the market.
Metrologic's goal was to develop a hand-held scanner that was equally effective as a presentation device and would incorporated several innovative new features while making it durable enough. Flash ROM upgrades, data editing utilities and user-replaceable cables lead the extensive features list of what has become the industries guide for measuring hand-held laser bar code scanners, MS9520 Voyager.
Flash ROM allows the firmware to be upgraded easily, and as software updates become available, each Voyager can be updated with all of the latest features utilizing an easy-to-use Windows-based program. Using Bits 'n' Pieces data editing utility, users can custom-edit the bar code data to meet the requirements of the host system.
Voyager now includes the ability to decode the emerging Reduced Space Symbology (RSS). Industries including supermarkets, pharmaceutical, and healthcare are beginning to utilize this new symbology.
Metrologic MS 9520 Voyager - barcode scanner
Barcode scanner - handheld - USB
Minimum Bar Width
0.127 mm
Scan Field Width
64 mm - 249 mm
Scan Element Type
Visible laser diode
Scan Speed
72 line / sec
Wired
7.8 cm x 4 cm x 19.8 cm
0.1 kg
5 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
0.127 mm
Scan Field Width
64 mm - 249 mm
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
72 line / sec
Max Working Distance
20.3 cm
Skew (Degrees)
52
Pitch (Degrees)
68
Print Contrast Signal (PCS)
35%
Decode Capability
Code 93, Code 39, RSS Code, Code 39 Full ASCII, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey
Wired
OK Notification
Beeper, LED indicator
Triggered, Reduced Space Symbology (RSS)
1 x USB
Stand
1 x USB cable
FCC Class B certified, UL, cUL, EN55022, ICES-003
7.8 cm
4 cm
19.8 cm
0.1 kg
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 - 95%
Drop Specification
1.5 m
Scroll to top
