BT.com
Wishlist
Metrologic Voyager 9520 USB Scanner
Metrologic Voyager 9520 USB...
£95.61
34 in stock
£95.61
Add to wishlist
Delivery
Standard 1-3 working days
Honeywell's MS9520 Voyager hand-held, single-line laser scanner offers aggressive scanning of all standard 1D bar codes. The Voyager series of hand-held, single-line bar code scanners has united form with function in becoming the industry benchmark for value and performance.
This sleek scanner features patented automatic infrared activation and decodes all standard 1D bar codes. For presentation scanning, Honeywell offers a stand with automatic in-stand detection technology.
The MS9521 VoyagerHD is ideal for applications that require high density scanning, delivering quick and accurate scanning of 1D bar codes as small as 3 mil. Expand scanner functionality by purchasing the MS9524 VoyagerPDF, which delivers aggressive scanning of all standard 1D bar codes, including PDF.
Honeywell MS9520 Voyager - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
0.127 mm
Scan Element Type
Visible laser diode
Scan Speed
72 line / sec
Wired
7.8 cm x 5.6 cm x 19.8 cm
149 g
5 years warranty
Light grey
Barcode
Interface Type
USB
Minimum Bar Width
0.127 mm
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
72 line / sec
Skew (Degrees)
52
Pitch (Degrees)
68
Print Contrast Signal (PCS)
35%
Decode Capability
EAN/JAN, Code 93, Code 39, RSS Code, Bookland, Code 39 Full ASCII, UPC-A, UPC-E, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, UPC-A/EAN-13 with Extended Coupon Code
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Triggered, Reduced Space Symbology (RSS)
1 x USB
Stand
1 x USB cable
FCC Class B certified, UL, cUL, IEC 825-1/EN 60825-1 class 1, EN55022 Class B, ICES-003 Class B
7.8 cm
5.6 cm
19.8 cm
149 g
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 - 95%
Drop Specification
1.5 m to concrete
Scroll to top
