BT.com
Wishlist
Manhattan USB-HUB 28-Port Black
Delivery
Standard 3-5 working days
The Manhattan MondoHub features a high-capacity 4-amp power adapter with enough ports to manage a growing collection of USB-enabled devices. Unlike some other large capacity USB Hubs available on the market, the MondoHub features 4 SuperSpeed USB ports and can recharge devices or transfer data at lightning fast speeds.
The compact and durable case features the power and hub-to-PC ports on the side panel to help better organize connections and minimize cable clutter. This high-quality USB Hub also features automatic overcurrent protection for each port and hot-swapping Plug and Play connection. With a power switch for each port, the MondoHub gives users complete control over which devices are using power or valuable system resources.
Manhattan MondoHub - hub - 28 ports
Hub - 28 ports
Subtype
USB
Ports
24 x USB 2.0 + 4 x SuperSpeed USB
USB powered
USB 1.1, USB 2.0, USB 3.0
AC 100/230 V (50/60 Hz)
22.9 cm x 11.2 cm x 2.3 cm
354 g
Apple MacOS X 10.0 or later, Microsoft Windows 2000/XP/Vista/7
Bundled Services
Hub - 28 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
24 x USB 2.0 - Type A , 4 x USB 3.0 - Type A
External power adapter
1 x USB cable - 0.8 m
Plug and Play, FCC, WEEE
22.9 cm
11.2 cm
2.3 cm
354 g
Limited warranty - lifetime
Scroll to top
