BT.com
Wishlist
Manhattan LCD Mount Double Link Monitor Arms
Delivery
Standard Due date unavailable
The Manhattan LCD monitor pole with double-link swing arm provides a secure and elevated position for two flat-screen monitors to help free up valuable desk and work space. Its fully adjustable tilt, rotate, side-to-side, height and tension settings enable a comfortable and productive viewing position that helps reduce eye fatigue and neck and back strain. LCD monitors can be easily rotated around the pole to allow others to view presentations and other multimedia displays from almost any direction.
Durable die-cast aluminum construction and a sturdy clamp provide a quick, easy and secure mount to a desktop or other horizontal surface. VESA compliant and ready to install with included hardware, there's no need to drill holes into desks or countertops.
Manhattan - mounting kit
Mounting kit
Mounting Components
Desk clamp mount, mounting pole, double swing arm, screws
41.3 cm
Tilt
4.6 kg
Recommended Use
2 LCD displays
Recommended Display Size
13"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
12 kg
Material
Aluminium
41.3 cm
4.6 kg
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
2 LCD displays
13"-24"
Tilt
Max Load Weight
12 kg
Adjustable height, rotating
Limited warranty - lifetime
Scroll to top
