BT.com
Wishlist
Mad Catz R.A.T 9 Wireless Gaming Mouse - 6400DPI - Laser - White
Delivery
Standard Due date unavailable
Mad Catz R.A.T. 9 Wireless Gaming Mouse for PC and Mac
Take the lead and lose the wire with the top-of-the-range Mad Catz R.A.T. 9 Wireless Gaming Mouse. The power and performance of the R.A.T. 7 combine with next-generation wireless technology for an unsurpassed gaming experience.
Perfect Your Grip
How do you hunt? Whether you palm' the mouse or claw' it, the Mad Catz R.A.T. 9 can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel of the R.A.T. 9 moves forwards, backwards, and pivots outwards, giving you perfect positioning for effortless gaming.
Lightweight Aluminum Chassis
Strong yet nimble, the solid metal frame forms the core of the Mad Catz R.A.T. 9 for enhanced rigidity.
Next-gen 2.4GHz Wireless Technology
A staggering 1ms response time ensures that your lightning-fast reactions remain lightning fast.
Wireless Receiver/Recharge Dock
Keeps gaming for as long as the gamer - - the Mad Catz R.A.T. 9 is a 24/7 wireless beast, shipping with a pair of custom built lithium-ion battery cells. One powers the R.A.T. while the other one charges in the dock, allowing you to perform a 'hot swap' whenever and wherever needed.
True 6400 DPI Laser Sensor
The Mad Catz R.A.T. 9 Gaming Mouse's new-generation 'twin-eye' laser sensor reads each axis separately and tracks up to a stunning six meters per second with pinpoint accuracy. Pro gamers who prefer low sensitivity with high movement speed will always experience correct tracking and precision.
Custom Weight System
Like it light or heavy? Maybe you change the weight to suit your game? No matter, the Mad Catz R.A.T. has you covered. Add or subtract up to seven 6-gram weights in an instant to obtain the perfect weight for a perfect feel. And when not in use, the weights can be safely stored in the weight storage container which nestles into the supplied charging dock.
Precision Aim Mode
Hit your target the first time every time. Use the included Mad Catz Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. You can even use the software to assign programmable features to the Precision Aim button, and then use it to execute keyboard commands like macros and keybindings - - a deadly weapon that will hit your enemy exactly where it hurts the most.
Take Control of Your Games
With the included programming software, you can create an unlimited number of profiles. For example, create a unique profile for each game, character or for different builds (sniper, tank, healer, and more). Within each profile, you can customize your DPI settings, set Precision Aim sensitivity, create powerful macros and set keybindings. Each profile allows for 18 user-definable commands via six programmable buttons over three modes.
Powerful Macro Programming
The R.A.T. 9 features six programmable buttons including the scroll wheel. Each button can be easily programmed to perform complex macros or simple key commands. You have the power to customize your R.A.T. for your games.
Customize Your DPI Settings
Four user-definable DPI settings range from 25 to 6400 and the DPI button lets you easily cycle through your custom settings.
Interchangeable Pinkie Grips and Palm Rests
3 Pinkie Grips / 3 Palm Rests:
- One Pinkie Grip / One Palm Rest featuring the same soft-touch finish as found on the body of the Mad Catz R.A.T.
- One Pinkie Grip / One Palm Rest with a rubber inlay for enhanced grip
- One Pinkie Grip that offers a `wing shaped' design, allowing you to rest your pinkie finger during play for increased grip
- One Palm Rest that is 4mm thicker to increase the height of the R.A.T.
Powerful Mad Catz Programming Software
Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your programmable buttons and modes. Easy, quick, and the all power you need right on your computer.
Box Includes:
- Wireless Mouse
- USB Receiver
- 2x Rechargeable Lithium-Ion Batteries
- Charging Dock
- 7x Removable 6g Weights
- Weight Storage Canister
- 2x Extra Palm Rests
- 2x Extra Pinkie Rests
Mad Catz R.A.T.9 - mouse - 2.4 GHz - white
Mouse
Wireless - 2.4 GHz
White
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Movement Resolution
6400 dpi
Performance
1 ms response time, realtime sensitivity switching 25 - 6400 dpi
Programmable buttons, scrolling wheel, Macros, sensitivity adjustment, adjustable size, Weight System, Precision Aim Mode, interchangeable pinkie grip, interchangeable palm rest, aluminium body
1
Apple MacOS X 10.6.6 or later, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Mouse
Wireless Receiver
White
Input Device
Wireless
2.4 GHz
Laser
Movement Resolution
6400 dpi
Performance
Additional battery, 2 pinkie grips, 2 palm rests, docking station, weight modules (7 pcs.)
Mouse charging stand
Lithium Ion
Installed Qty
1
Software Included
Scroll to top
