Click to visit BT.com
BT.com
Wishlist
Mad Catz R.A.T 7 Gaming Mouse - 6400DPI Laser - Matte Black
Quicklinx: 8CH5WS00
Mfr#: MCB4370800B2/04/1
Mad Catz R.A.T. 7 Gaming Mouse for PC and Mac
Play to win with the Mad Catz R.A.T. 7. Uncompromising, unparalleled, and unmatched, the R.A.T. 7 helps you play like the pros, combining state-of-the-art technology with a jaw-dropping array of customizable features to produce the next step in the evolution of the mouse.
Perfect Your Grip
How do you hunt? Whether you 'palm' the mouse or 'claw' it, the Mad Catz R.A.T. 7 can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel moves forwards, backwards, and even pivots outwards to provide a comfortable platform from which all thumb buttons are easily accessible.
Lightweight Aluminum Chassis
Strong yet nimble, the solid metal frame forms the core of the Mad Catz R.A.T. 7 for enhanced rigidity.
True 6400 DPI Laser Sensor
The Mad Catz R.A.T. 7 Gaming Mouse's new-generation 'twin-eye' laser sensor reads each axis separately and tracks up to a stunning six meters per second with pinpoint accuracy. Pro gamers who prefer low sensitivity with high movement speed will always experience correct tracking and precision.
Custom Weight System
Like it light or heavy? Maybe you change the weight to suit your game? No matter, the Mad Catz R.A.T. 7 has you covered. Add or subtract up to five 6-gram weights in an instant to obtain the perfect weight for a perfect feel. And when not in use, the weights can be safely stored in the supplied weight storage container.
Precision Aim Mode
Hit your target the first time every time. Use the included Mad Catz software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. You can even use the software to assign programmable features to the Precision Aim button, and then use it to execute keyboard commands like macros and keybindings - - a deadly weapon that will hit your enemy exactly where it hurts the most.
Take Control of Your Games
With the included programming software, you can create an unlimited number of profiles. For example, create a unique profile for each game or character, or for different builds (sniper, tank, healer, and more). Within each profile, you can customize you DPI settings, set Precision Aim sensitivity, create powerful macros and set keybindings. Each profile allows for 18 user-definable commands via six programmable buttons over three modes.
18 User-definable Commands via 3 Mad Catz Modes
Toggle between three individual Cyborg R.A.T. modes at the touch of a button. Change sensitivity or programmable button actions in an instant and gain immediate access to a mind-boggling 18 commands!
6 Programmable Buttons
Combine the programmable buttons with standard left and right mouse buttons and it all adds up to eight buttons with which you can punish your competition. Assign your choice of key gaming actions to programmable buttons to create your own custom profiles.
Customize Your DPI Settings
Four user-definable DPI settings range from 25-6400 in increments of 25 and the DPI button lets you easily cycle through your custom settings
Interchangeable Pinkie Grips and Palm Rests
3 Pinkie Grips / 3 Palm Rests:
- One Pinkie Grip / One Palm Rest featuring the same soft-touch finish as found on the body of the Mad Catz R.A.T.
- One Pinkie Grip / One Palm Rest with a rubber inlay for enhanced grip
- One Pinkie Grip that offers a `wing shaped' design, allowing you to rest your pinkie finger during play for increased grip
- One Palm Rest that is 4mm thicker to increase the height of the R.A.T.
Powerful Mad Catz Programming Software
Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your programmable buttons and modes. Easy, quick, and the all power you need right on your computer.
Box Includes:
Mouse with Gold-plated USB Connector
5X Removable 6g Weights
Weight Storage Canister
2X Extra Palm Rests
2X Extra Pinkie Rests
CYBORG R.A.T. 7 - mouse - USB
Mouse
Wired - USB
Movement Detection Technology
Dual laser
Buttons Qty
7
Movement Resolution
6400 dpi
Performance
50 G maximum acceleration, realtime sensitivity switching 25 - 6400 dpi
Programmable buttons, scrolling wheel, rocker switch, Twin-Eye Laser technology, adjustable weight, switchable resolution, polytetrafluoroethylene (PTFE) feet, golden USB plug, adjustable size
1 x USB cable - integrated
Microsoft Windows XP 64-bit Edition, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
Mouse
Input Device
Wired
USB
Dual laser
Buttons Qty
7
Movement Resolution
6400 dpi
Performance
1 x USB 2.0 - 4 pin USB Type A
Weight system, 3 palm rests, 3 pinkie grips
USB 2.0
Software Included
ST Programming Software
