BT.com
Wishlist
Mad Catz R.A.T 5 Gaming Mouse - 5600DPI Laser - Matte Black
Delivery
Standard Due date unavailable
Mad Catz R.A.T. 5 Gaming Mouse for PC and Mac
Step up to the performance and comfort of the Mad Catz R.A.T. 5 Gaming Mouse and come hunt with the big boys. Customize your R.A.T. 5 to create a truly unique experience with a mouse that transforms and adapts to suit your needs.
Perfect Your Grip
How do you hunt? Whether you 'palm' the mouse or 'claw' it, the Mad Catz R.A.T. 5 can quickly and easily adapt by adjusting in length to suit your hand size and grip style.
Gaming-grade 5600 DPI Laser
Featuring a gaming-grade laser sensor with pinpoint accuracy, the Mad Catz R.A.T. 5 is truly ahead of the game.
Lightweight Aluminum Chassis
Strong yet nimble, the solid metal frame forms the core of the Mad Catz R.A.T. 5 for enhanced rigidity.
Custom Weight System
Like it light or heavy? Maybe you change the weight to suit your game? No matter, the Mad Catz RAT 5 has you covered. Add or subtract up to five 6-gram weights in an instant to obtain the perfect weight for a perfect feel. And when not in use, the weights can be safely stored in the supplied weight storage container.
Precision Aim Mode
Hit your target the first time every time. Use the included Mad Catz Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. You can even use the software to assign programmable features to the Precision Aim button, and then use it to execute keyboard commands like macros and keybindings - - a deadly weapon that will hit your enemy exactly where it hurts the most.
Take Control of Your Games
With the included programming software, you can create an unlimited number of profiles. For example, create a unique profile for each game or character, or for different builds (sniper, tank, healer, and more). Within each profile, you can customize you DPI settings, set Precision Aim sensitivity, create powerful macros and set keybindings. Each profile allows for 18 user-definable commands via six programmable buttons over three modes.
Powerful Macro Programming
The R.A.T. 5 features six programmable buttons including the scroll wheel. Each button can be easily programmed to perform either complex macros or simple key commands. You have the power to customize your R.A.T. Gaming Mouse for your games.
Customize Your DPI Settings
Four user-definable DPI settings range from 100 to 5600 and the DPI button lets you easily cycle through your custom settings.
Powerful Mad Catz Programming Software
Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your programmable buttons and modes. Easy, quick, and the all power you need right on your computer.
Box Includes:
Mouse with Gold-plated USB Connector
5X Removable 6g Weights
Weight Storage Canister
CYBORG R.A.T. 5 - mouse - USB
Mouse
Wired - USB
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
5600 dpi
Performance
30 G maximum acceleration, realtime sensitivity switching 100 - 5600 dpi
Programmable buttons, scrolling wheel, adjustable weight, switchable resolution, polytetrafluoroethylene (PTFE) feet, golden USB plug, adjustable size, Always-On Mode, braided cable
1 x USB cable - integrated
Microsoft Windows XP 64-bit Edition, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6.6 or later
Microsoft Certification
Compatible with Windows 7
Mouse
Input Device
Wired
USB
Laser
Buttons Qty
7
Movement Resolution
5600 dpi
Performance
1 x USB 2.0 - 4 pin USB Type A
Weight modules (5 pcs.)
Software Included
ST Programming Software
Scroll to top
