BT.com
Wishlist
Mad Catz R.A.T 3 Gaming Mouse - 3500DPI Optical - White
Delivery
Standard Due date unavailable
Sleek design, cutting-edge form factor and a host of programmable action buttons help you keep ahead of the competition no matter what the game
Gaming-grade 3500 DPI Optical Sensor
Featuring a precise, gaming-grade optical sensor with utmost accuracy, the Mad Catz R.A.T. 3 is truly ahead of the game.
Precision Aim Mode
Hit your target the first time every time. Use the included Mad Catz Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. You can even use the software to assign programmable features to the Precision Aim button, and then use it to execute keyboard commands like macros and keybindings - - a deadly weapon that will hit your enemy exactly where it hurts the most.
Take Control of Your Games
With the included programming software, you can create an unlimited number of profiles. For example, create a unique profile for each game or character, or for different builds (sniper, tank, healer, and more). Within each profile, you can customize you DPI settings, set Precision Aim sensitivity, create powerful macros and set keybindings. Each profile allows for nine user-definable commands via three programmable buttons over three modes.
Customize Your DPI Settings
Four user-definable DPI settings range from 450 to 3500 and the DPI button lets you easily cycle through your custom settings.
Powerful Mad Catz Programming Software
Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your programmable buttons and modes. Easy, quick, and the all power you need right on your computer.
CYBORG R.A.T. 3 - mouse - USB - white
Mouse
Wired - USB
White
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
3500 dpi
Performance
1000 reports per second, 20 G maximum acceleration, realtime sensitivity switching 450/900/1800/3500 dpi
Programmable buttons, scrolling wheel, polytetrafluoroethylene (PTFE) feet, golden USB plug, braided cable
1 x USB cable - integrated
Apple MacOS, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
Mouse
White
Image Colour Disclaimer
The image of the product displayed may be of a different colour
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
3500 dpi
Performance
1 x USB 2.0 - 4 pin USB Type A
USB 2.0
Software Included
ST Programming Software
Scroll to top
