Click to visit BT.com
BT.com
Wishlist
Mad Catz M.M.O 7 Gaming Mouse - Laser
Quicklinx: 8CH7WS00
Mfr#: MCB437130002/04/1
Create Your Perfect Gaming Interface
Level up your gaming hardware with the Mad Catz M.M.O. 7 Gaming Mouse. Mad Catz took all of the standout features and technology from the world's most adjustable gaming mouse - - the FPS-revolutionizing R.A.T. - - and then enhanced control and comfort to create the ultimate weapon for MMO gamers. Whether you play WoW, EVE, The Lord of the Rings Online, Star Wars: The Old Republic, Guild Wars, or RIFT, the Mad Catz M.M.O. 7 delivers powerful macros and programmability to support any MMO.
Assign 90 Programmable Commands for ANY Game
15 programmable buttons team up with a 3-position MMO mode switch and a 2-position MMO shift button to forge 90 user-definable in-game commands. Combine the programmable buttons with standard left and right mouse buttons and it all adds up to 17 buttons with which you can punish your competition.
Unique 5D Button Enables 5 Commands with a Single Control
Use the 5D Button to click up and down, left and right, and press in. Gain the competitive advantage by always knowing exactly where each and every mouse button resides - - without the hassles of training aids or the need to actually look at the mouse to locate a feature. Perfect positioning under your thumb provides lightning-fast access to your most important gaming commands. Mimicking the size and shape of the Precision Aim button found on its rodent brethren, R.A.T. owners will feel right at home.
Intuitive World of Warcraft Plug-in
The talented developers at Mad Catz have crafted an add-on that enables you to drag and drop spells, inventory items and macros directly to the buttons of the mouse. No more lengthy setup - - just jump in and quickly create the perfect configuration without the need to change any of your existing action bar settings.
Powerful Mad Catz Programming Software
Mad Catz' proprietary programming software gives you total control over the M.M.O. 7 Gaming Mouse's unique features. Adjust macros and set keybindings, tweak cursor sensitivity, create custom profiles for each game, and assign commands to your programmable buttons and modes. Easy, quick, and the all power you need right on your computer.
Fully Adjustable RGB Backlighting
Choose one of 16 million RGB colors to backlight the left and right mouse buttons. Whether you want an added touch of lighting to your rig, or indication of ActionLock button status, the included programming software allows you to adjust the backlighting to suit your preference.
Dual ActionLock Buttons Enable Fatigue-Free Gaming
When you're several hours into a raid and your fingers start to feel the effects, a single click of an ActionLock button delivers much-needed relief. Each ActionLock button gives constant input to the main left or right mouse buttons when locked. Activate one for fatigue-free camera movement and character control, or unlock it to resume obliterating your foes as normal.
Perfect Your Grip for Extended Gaming Sessions
How do you hunt? Whether you 'palm' the mouse or 'claw' it, the Mad Catz M.M.O. 7 Gaming Mouse can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel moves forwards and backwards, and even pivots outwards to provide a comfortable platform from which all thumb buttons are easily accessible.
True 6400 DPI 'Twin-Eye' Laser Sensor with 4 Custom Settings
The Mad Catz M.M.O. 7 Gaming Mouse's new-generation 'twin-eye' laser sensor reads each axis separately and tracks up to a stunning six meters per second with pinpoint accuracy. Pro gamers who prefer low sensitivity with high movement speed will always experience correct tracking and precision. Four user-definable DPI settings range from 25 to 6400 and the DPI button lets you easily cycle through your custom settings.
Custom Weight System
Like it light or heavy? Maybe you change the weight to suit your game? No matter, the Mad Catz M.M.O. 7 Gaming Mouse has you covered. Add or subtract one of the five 6-gram weights in an instant to give yourself the perfect weight for a perfect feel. When not in use, the weights can be safely stored in the supplied storage canister.
Interchangeable Pinkie Grips and Palm Rests
3 Pinkie Grips / 3 Palm Rests:
- One Pinkie Grip / One Palm Rest featuring the same soft-touch finish as found on the body of the Mad Catz M.M.O. 7.
- One Pinkie Grip / One Palm Rest with a rubber inlay for enhanced grip.
- One Pinkie Grip with a 'wing shaped' design which allows you to rest your pinkie finger during play for increased comfort.
- One Palm Rest that is 4mm thicker to increase the height of the mouse.
Box Includes:
- Mad Catz M.M.O. 7 Gaming Mouse
- 5x 6-Gram Weights with Storage Canister
- 2x Additional Pinkie Rests
- 2x Additional Palm Rests
CYBORG M.M.O. 7 - mouse - USB
Mouse
Wired - USB
Movement Detection Technology
Dual laser
Buttons Qty
15
Movement Resolution
6400 dpi
Performance
50 G maximum acceleration, 1000 reports per second, realtime sensitivity switching 25 - 6400 dpi
Programmable buttons, scrolling wheel, backlighting, Twin-Eye Laser technology, adjustable weight, golden USB plug, braided cable
1 x USB cable - integrated
Apple MacOS, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP (32/64 bits)
Mouse
Input Device
Wired
USB
Dual laser
Buttons Qty
15
Movement Resolution
6400 dpi
Performance
1 x USB 2.0 - 4 pin USB Type A
Weight modules (5 pcs.), 3 palm rests, 3 pinkie grips
USB 2.0
Software Included
ST Programming Software
