BT.com
Wishlist
Mad Catz G.L.I.D.E 9 Gaming Surface
Delivery
Standard Due date unavailable
The Ideal Companion for Gaming Mice
Don't settle for just any mouse pad, Mad Catz' G.L.I.D.E. 9 Aluminum Gaming Surface is designed to maximize your performance and give you the competitive edge.
Constructed from anodized aluminum, the G.L.I.D.E. 9 is scientifically proven to enhance your gaming mouse's tracking performance by 100 percent. Custom materials and color enhancements increase your mouse's sensor accuracy and provide smooth movement to give you a distinct advantage over your rivals. The G.L.I.D.E. 9 is fully compatible with optical sensors - - but optimized for laser sensors - - and delivers total control with maximum accuracy. Plus, at twice the size than the average mouse pad, the XL surface area is ideal for all gaming styles. Give your gaming mouse a sleek and exceptional place to call home with the G.L.I.D.E. 9 Aluminum Gaming Surface from Mad Catz.
100% Better Tracking Performance
When tested against comparable gaming surfaces, the G.L.I.D.E. 9 provides a 100 percent increase in tracking performance. Fully compatible with optical sensors - - but optimized for mice which employ laser sensors - - the G.L.I.D.E. 9 delivers total control and utmost accuracy for any mouse.
Highly Polished Low-friction Surface
Mouse movement on the G.L.I.D.E. 9 Gaming Surface is four percent smoother than gaming surfaces constructed from comparable materials. Carefully selected materials coupled with an ultra-smooth surface texture promote flawless mouse tracking.
XL Surface Area
Measuring 140 percent larger than the average mouse pad, the XL surface area is ideal for all styles of mousing. Whether you prefer to keep your DPI low or high, or your mouse movement large or minimal, the G.L.I.D.E. 9 delivers extremely detailed mouse feedback.
Mad Catz R.A.T. 7 Gaming Mouse Not Included
Scientifically Proven to Enhance Sensor Performance
In order to track movement, the laser sensor in a mouse relies on receiving specific information from your gaming surface, obtained through reflections of the laser beam. The surface upon which you use your mouse is very important. Use it on a dark surface that absorbs light from the same spectrum in which the laser operates and the sensor won't receive enough information, if any at all, and can't detect that the mouse is moving.
The surface shouldn't just reflect the laser like a mirror, known as specular reflection. Instead, a mouse operates at peak efficiency when light reaching the sensor reflects in a broad range of directions, known as diffuse reflection.
The entire range of G.L.I.D.E. surfaces meets the requirements of proper reflection. Very specific colors and materials ensure that your mouse's laser sensor receives an abundance of reflected laser light in order to achieve unprecedented levels of response. When coupled with any G.L.I.D.E. Gaming Surface, you can be confident that the laser in your mouse is operating at peak efficiency.
Premium Carry Case Included
For safe transport en route to your next LAN party, the G.L.I.D.E. 9 comes equipped with a durable handmade carry case. After you finish destroying the competition, just slide the surface back in its premium envelope-style case.
Product Includes:
Premium Handmade Carry Case
Product Dimensions:
15.35 x 11.61 x 0.09 (Inches)
390 x 295 x 2.5 (Millimeters)
Mad Catz G.L.I.D.E.9 Aluminum Gaming Surface - mouse pad
Mouse pad
Package Content
Carrying case
Product Material
Anodised aluminium
Mouse pad
Package Content
Carrying case
Product Material
Anodised aluminium
Scroll to top
