BT.com
Wishlist
Mad Catz G.L.I.D.E 7 Gaming Surface
Delivery
Standard Due date unavailable
Don't settle for just any mouse pad, Mad Catz' G.L.I.D.E. 7 Silicone Gaming Surface is designed to maximize your performance and give you the competitive edge. Constructed from premium silicone, the G.L.I.D.E. 7 is scientifically proven to enhance your gaming mouse's tracking performance by 1,000 percent. Custom materials and low-friction coating increase your mouse's sensor accuracy and provide smooth movement to give you a distinct advantage over your rivals. The G.L.I.D.E. 7 is fully compatible with optical sensors - but optimized for laser sensors - and delivers total control with maximum accuracy. Plus, at twice the size than the average mouse pad, the XL surface area is ideal for all gaming styles. Give your gaming mouse a sleek and exceptional place to call home with the G.L.I.D.E. 7 Silicone Gaming Surface from Mad Catz.
Mad Catz G.L.I.D.E. 7 Gaming Surface - mouse pad
Mouse pad
Package Content
Carrying case
Product Material
Silicone
40 cm x 30 cm
Mouse pad
Package Content
Carrying case
Product Material
Silicone
40 cm
30 cm
Thickness
0.1 cm
Scroll to top
