Click to visit BT.com
BT.com
Wishlist
Mad Catz G.L.I.D.E 5 Gaming Surface
Quicklinx: 8CHFWS00
Mfr#: MCB4380900A1/06/1
The Ideal Companion for Gaming Mice
Give your gaming mouse a place to call home with the G.L.I.D.E. 5 Gaming Surface from Mad Catz. Constructed from premium microfiber-covered foam with a high-grip rubber underside for dependable stability, the low-friction coating facilitates smooth mouse movement with effortless control. Custom materials and colors enhance your mouse's sensor performance to give you a distinct advantage over online rivals.
Optimized for Optical Sensors
Although the G.L.I.D.E. 5 works great with laser sensors, meticulous attention to the surface's material and design help ensure optimization with optical sensors. Optical sensors utilize a tiny camera which takes pictures of your gaming surface - - thousands per second - - and then analyze those images to translate them into mouse cursor movement. The precise weave pattern of the material coating the G.L.I.D.E. 5 ensures that your optical mouse's sensor receives incredibly accurate information, resulting in trouble-free aiming in every game you play.
XXL Surface Area
Measuring a whopping 317 percent larger than the average mouse pad, the double-XL surface area is ideal for gamers whose style of mousing is low in sensitivity. When you prefer to keep your DPI low - - and lots of mouse movement translates into very little in-game aiming movement - - an oversize gaming surface is a necessity.
Low-friction Fabric Weave
Mouse movement on the G.L.I.D.E. 5 Gaming Surface is 13 percent smoother than gaming surfaces constructed from comparable materials. Carefully selected materials coupled with an ultra-smooth surface texture promote flawless mouse tracking.
Product Includes:
G.L.I.D.E. 5 Foam Gaming Surface
Product Dimensions:
19.86 x 15.74 x 0.15 (Inches)
500 x 400 x 4 (Millimeters)
Saitek Cyborg G.L.I.D.E 7 Gaming Surface - mouse pad
Mouse pad
Product Material
Synthetic fabric, rubber foam
50 cm x 40 cm
Mouse pad
Product Material
50 cm
40 cm
