BT.com
Wishlist
Maclocks Space 10.6" Surface Enclosure With Pole Mount Kiosk - Black
Delivery
Standard Due date unavailable
The Maclocks Pole Surface Kiosk is the next in the line of surface tablet security display products that offers full cable management. Ideal for use as a display kiosk or information stand specifically in high volume areas. You can be confident that your device will stay continually connected and secure.
Fully constructed of high-grade aluminum for maximum security that won't bend or break creating a tamper proof solution for your Surface Tablet deployment.
The Pole Surface Stand displays your Surface at a 60 degree angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app.
Compulocks Surface Secure Space Enclosure with Pole Stand Kiosk Black - stand
Stand - table-top - lockable
Recommended Use
Tablet
Material
High-grade aluminium
Microsoft Surface 2, Pro, Pro 2
Material
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
Lockable
Scroll to top
