BT.com
Wishlist
Maclocks MacBook Pro 13 Case Lock
£57.07
40 in stock
£57.07
Add to wishlist
Delivery
Standard 3-5 working days
In most cases, MacBook Pro users use a cover/skin to protect their computers from dirt and external damage. Maclocks security cover is a simple, yet clever solution which incorporates a security slot into the actual MacBook Pro cover.
This smart skin mechanism slightly elevates the MacBook Pro above the surface, thus enhancing current venting system. The polymer security cover is engineered to support the MacBook Pro cooling process.
Once the case and cable are locked together, it's hard to detach the case without damaging the MacBook Pro. This makes the MacBook Pro with Retina display Lock flexible and light, not to mention stylish, so you can easily take it with you wherever you go.
Compulocks MacBook Lockable Case Bundle With T-Bar Cable Lock and MacBook Pro 13" Security Case / Cover Clear - security cable lock
Security cable lock
Package Content
2 x keys, security cover
Clear
Product Material
Steel
Length
1.83 m
Apple MacBook Pro with Retina display (13.3 in)
Security cable lock
Product Material
Steel
Package Content
Length
1.83 m
Clear
Scroll to top
