BT.com
Wishlist
Maclocks Mac Pro Lock
£52.69
29 in stock
£52.69
Add to wishlist
Delivery
Standard 3-5 working days
Maclocks has developed the first locking and anti-theft solution for the new Mac Pro powerhouse computer. A must have for Mac Pro users on any scale - perfect for computer labs, educational institutions, graphic design and recording studios.
The new Mac Pro Lock Bracket with Security Cable Lock fits comfortably underneath the cylinder lid to offer complete protection of the device and its hardware components. By designing the Mac Pro Lock to fit the curvature of the new Mac Pro and the bracket plate to sit securely over the power cable the lid is now doubly locked into place. The bracket plate has an extended lip that will allow you to attach the included Security Cable Lock ensuring your Mac Pro workstation and all its impressive (and expensive) hardware are not going anywhere.
Before locking the Security Cable to the bracket you will first want to tether the loop end around a solid and stable object like the leg of a table or desk. If you don't have a secure place to tether the cable to, select an anchor point from the drop-down selection and you'll be covered.
The simple design of the Mac Pro Lock system means it is really quick and easy to setup and secure your Mac Pro in minutes.
Maclocks security bracket
Security bracket
Package Content
Cable lock
Product Material
Stainless steel
Apple Mac Pro (Late 2013)
Security bracket
Product Material
Stainless steel
Package Content
Cable lock
Scroll to top
