BT.com
Wishlist
Maclocks iPad Space Enclosure Kiosk With a Pole Mount - White
Delivery
Standard Due date unavailable
This tablet stand with full cable management is ideal for use as a display kiosk or information stand specifically in high-volume areas. You can be confident that your device will stay continually connected and secure. Fully constructed of high-grade aluminum for maximum security it won't bend or break creating a tamper-proof solution for your tablet deployment. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app. With a minimal amount of setup required you can have your tablet enclosure kiosk ready to go in just a few minutes.
Compulocks - stand
Stand - table-top
Recommended Use
Tablet
Material
Aluminium
White
Apple iPad (3rd generation); iPad 2; iPad Air; iPad Air 2; iPad with Retina display (4th generation)
Material
Aluminium
White
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
Portrait to landscape movement
Apple iPad (3rd generation) , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad with Retina display (4th generation)
Scroll to top
