BT.com
Wishlist
Maclocks iPad Mini Space Enclosure Kiosk With Swan Mount - White
Maclocks iPad Mini Space Enclosure...
£144.40
Hurry, only 1 left in stock!
£144.40
Add to wishlist
Delivery
Standard 1-3 working days
The Swan iPad Enclosure Kiosk is the newest release from Maclocks. Elegantly designed with a white "swan-neck" sloping stand your new iPad Kiosk will bring a level of class to any setting.
The iPad stand is angled at 60 degrees for optimal viewing and sits 14 inches (35cm) high and at the base is 7 inches (18cm) wide. The iPad enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to your iPad when you need to take it with you or maintenance is required.
Compulocks iPad Secure Space Enclosure with Swan Stand Kiosk White - mounting kit
Mounting kit - table-top
Mounting Components
Desk stand, anti-theft enclosure
25.4 cm x 15.2 cm x 30.4 cm
Recommended Use
Tablet
White
Apple iPad mini; iPad mini 2; 3; 4
25.4 cm
15.2 cm
30.4 cm
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Table-top
Portrait to landscape movement, lockable
Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4
Scroll to top
