BT.com
Wishlist
Maclocks iPad Air POS Wall Swing Arm Mount Kiosk - Black
Delivery
Standard Due date unavailable
The Slide Swing is the most flexible solution for mounting an iPad POS system.
The Slide Swing mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
The swing arm pulls out up to 10.75" off the secured surface and is a great option for food truck, bar, or in kitchen display. Standard on all SLIDE POS models is the open sides for complete access to inputs and allows you to use the widest variety of card readers. Any card reader that uses the headphone, lightening or 30 Pin connector like the Square, PayPal Here, ID Tech Shuttle, ID Tech Unimag I and II, Magtek iDynamo and uDynamo, and many more will fit on the SLIDE Pro.
Compulocks iPad Secure Slide POS with Swing Arm Kiosk Black - mounting kit
Mounting kit - table-top, under-the-cabinet
Mounting Components
Swing arm, anti-theft enclosure
Recommended Use
Tablet
Apple iPad Air; iPad Air 2
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Table-top, under-the-cabinet
Rotating, portrait to landscape movement, swing out
Dimensions & Weight Details
Dimensions
Enclosure - width: 24.5 cm, depth: 3 cm, height: 24.5 cm
Apple iPad Air , Apple iPad Air 2
Scroll to top
