BT.com
Wishlist
Maclocks iPad Air POS Wall Flex Arm Mount Kiosk - Black
Delivery
Standard Due date unavailable
Slide Flex mount is the perfect display solution when space is limited and access to the POS is from all angles. The bendable arm allows for smooth movement between display angles and with a 90 degree rotating pivot you can operate in landscape or portrait orientation modes.
The flex arm at full reach comes out to 12" off the secured surface and is a great option for food truck, bar, or in kitchen display. Standard on all SLIDE POS models is the open sides for complete access to inputs and allows you to use the widest variety of card readers. Any card reader that uses the headphone, lightening or 30 Pin connector like the Square, PayPal Here, ID Tech Shuttle, ID Tech Unimag I and II, Magtek iDynamo and uDynamo, and many more will fit on the SLIDE POS enclosure.
Compulocks iPad Secure Slide POS with Flex Arm Kiosk Black - mounting kit
Mounting kit - surface mountable
Mounting Components
Anti-theft enclosure, flexible arm
24.5 cm x 3 cm x 24.5 cm
Recommended Use
Tablet
Apple iPad Air; iPad Air 2
24.5 cm
3 cm
24.5 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Surface mountable
Portrait to landscape movement
Apple iPad Air , Apple iPad Air 2
Scroll to top
