BT.com
Wishlist
Maclocks iPad Air POS Floor Stand Kiosk - White
Maclocks iPad Air POS Floor Stand...
£300.15
Hurry, only 2 left in stock!
£300.15
Add to wishlist
Delivery
Standard 1-3 working days
The SLIDE Stand iPad POS Stand is a complete display option to use your iPad POS in a professional setting. This POS Stand is a great option for use in front of the house or greeting function and will save you valuable counter or table top space.
The SLIDE Stand has a 45 degree screen angle for ideal viewing and safe interaction. The wires are housed in the base so you always have a clean look and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs. The iPad POS Stand has a stable, all steel base to prevent tip-overs at any screen angle.
Compulocks iPad Secure Slide POS with Adjustable Floor Stand Kiosk White - mounting kit
Mounting kit
Mounting Components
Anti-theft enclosure, floor stand
27.9 cm x 33 cm x 112 cm
Tilt
Recommended Use
Tablet
Material
Steel
White
Apple iPad Air; iPad Air 2
27.9 cm
33 cm
112 cm
Material
Steel
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Tilt
Adjustable height, portrait to landscape movement, lockable, ventilation system
Dimensions & Weight Details
Dimensions
Enclosure - width: 24.5 cm, depth: 3 cm, height: 24.5 cm , Base - width: 27.9 cm, depth: 33 cm, height: 112 cm
Apple iPad Air , Apple iPad Air 2
Scroll to top
