BT.com
Wishlist
Maclocks Galaxy 8" Space Enclosure With Flip Stand Kiosk - White
Delivery
Standard Due date unavailable
The tastefully designed Space Flip is the optimal Galaxy Tab Kiosk for both professional and personal use. The flipping movement of this Galaxy Tab stand conveniently allows the Galaxy screen to be easily shared by opposing sides of a table. It gently rotates between portrait or landscape orientation modes for a fully functional display unit.
The two part rectangular base can be mounted gracefully and steadily on any counter top, wall or flat surface. The cubed base allows for cable management and security, and it fits over most power outlets with a 3.6 x 2 inch cutout. The base and enclosure have keyed locks for easy access to the wires and to the when maintenance is required.
Compulocks Galaxy Secure Space Enclosure with Flip Kiosk Base White - mounting kit
Mounting kit - wall-mountable, table-top, surface mountable
Mounting Components
Flip base, flip stand
Tilt
Recommended Use
Tablet
White
Samsung Galaxy Tab 3 (8 in), Tab 4 (8 in)
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Wall-mountable, table-top, surface mountable
Cable Management
Integrated cable management
Tilt
Portrait to landscape movement, lockable
Dimensions & Weight Details
Dimensions
Base - width: 12.7 cm, depth: 10.16 cm, height: 6.35 cm
Scroll to top
