BT.com
Wishlist
Maclocks Galaxy 10.1" Space Enclosure With Pole Mount Kiosk - White
Delivery
Standard Due date unavailable
The Maclocks Pole Galaxy Tab is the next in the line of Galaxy Tab security display products that offers full cable management. Ideal for use as a display kiosk or information stand specifically in high volume areas. You can be confident that your device will stay continually connected and secure.
Fully constructed of high-grade aluminum for maximum security that won't bend or break creating a tamper proof solution for your Galaxy Tab deployment.
The Pole Galaxy Tab Stand displays your Galaxy at a 60 degree angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app. With a minimal amount of setup required you can have your Galaxy Tab enclosure kiosk ready to go in just a few minutes.
Compulocks Galaxy Secure Space Enclosure with Pole Stand Kiosk White - stand
Stand - table-top
Recommended Use
Tablet
Recommended Display Size
10"
Material
Aluminium
White
Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 3 (10.1 in), Tab 4 (10.1 in)
Material
Aluminium
White
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
10"
Portrait to landscape movement, lockable, tamper resistant
Scroll to top
