BT.com
Wishlist
Maclocks Galaxy 10.1" Space Enclosure Swan Mount Kiosk - White
Delivery
Standard Due date unavailable
The Galaxy Swan Kiosk for Galaxy Tab 7/8/10.1 and Galaxy Note 10.1 is the newest release from GalaxyEnclosures. Elegantly designed with a white "swan-neck" sloping stand your Galaxy Kiosk bring a level of class to any setting.
The Galaxy stand is angled at 60 degrees for optimal viewing and sits 14 inches (35 cm) high and at the base is 7 inches (18 cm) wide. The enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to the your Galaxy tablet when you need to take it with you or maintenance is required.
Compulocks Galaxy Secure Space Enclosure with Swan Stand Kiosk White - stand
Stand - table-top
Recommended Use
Tablet
White
Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 3 (10.1 in), Tab 4 (10.1 in)
White
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Portrait to landscape movement, lockable
Dimensions & Weight Details
Dimensions
Base - width: 18 cm
Scroll to top
