BT.com
Wishlist
Maclocks Galaxy 10.1" Full Metal Jacket Enclosure Swing Arm Mount
Maclocks Galaxy 10.1" Full Metal...
£157.28
£157.28
Add to wishlist
Delivery
Standard Due date unavailable
The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero secure mount is the ideal Galaxy Tab security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero Mount is closed on all sides to provide a tamper-proof security solution. The charging cable is secured within the enclosure with an opening for the wire to allow for mounted charging.
The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
Compulocks Galaxy Secure Metal Jacket Enclosure with Swing Arm Kiosk Black - mounting kit
Mounting kit - wall-mountable
Mounting Components
Swing arm, anti-theft enclosure
30 cm x 20 cm
Adjustable Depth
0-27.3 cm
544 g
Recommended Use
Tablet
Material
Aluminium
Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi
30 cm
20 cm
Adjustable Depth
0-27.3 cm
544 g
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
Dimensions & Weight Details
Dimensions
Enclosure - width: 30 cm, depth: 20 cm, height: 2 cm , Arm - depth: 27.3 cm
Scroll to top
