BT.com
Wishlist
Lumens Gooseneck Full HD 1080p Resolution Document Camera
Lumens Gooseneck Full HD 1080p...
£379.76
26 in stock
£379.76
Add to wishlist
Delivery
Standard 1-3 working days
Equipped with a professional image sensor with low noise and vivid color reproduction, it supports extremely tremely high definition Full HD 1080p, SXGA, and vanes signal formats for crystal-clear image. Highly flexible and joint-free gooseneck design ensures smooth quality without vibration, easy to use, and 3600 viewing angle.
Lumens DC 170 - digital document camera
Digital document camera
Audio
Yes : built-in microphone
42 cm x 14 cm x 39.5 cm
1.9 kg
Wired
Camera
Optical Zoom
8.5 x
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Focus Adjustment
Automatic (min distance 4 cm )
USB 2.0 , VGA, HDMI
Digital image rotation, SD-card slot, image flip, image mirror, built-in LED lights, security lock slot (cable lock sold separately)
Audio Support
Wired
42 cm
14 cm
39.5 cm
1.9 kg
Camera
Max Digital Video Resolution
1920 x 1080
Digital Zoom
10
Still Image Capture Resolution
1280 x 960, 1024 x 768, 1280 x 768, 1920 x 1080
Lens Construction
Optical Zoom
8.5 x
Focus Adjustment
Automatic
Min Focus Distance
4 cm
Video
VGA, HDMI
Computer Interface
USB 2.0
1 x USB 2.0 - 4 PIN USB Type B , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI output - RCA , 1 - RS-232/composite video output , 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio - output
Power supply - internal AC 120/230 V
Apple MacOS X, Microsoft Windows Vista / XP / 7
Scroll to top
