BT.com
Wishlist
Logitech Z506 5.1 Surround Sound Speakers (75 Watts)
Logitech Z506 5.1 Surround Sound...
£69.22
2 in stock
£69.22
Add to wishlist
Delivery
Standard 3-5 working days
Surround Sound Speakers Z506
Be moved by big, 5.1 sound. With 75 watts (RMS) of room-filling sound and a powerful subwoofer, this system will bring your music, movies, and games to life
The Logitech® Surround Sound Speakers Z506 put you in the middle of your music, movies and games, with immersive 5.1 surround sound. A variety of inputs let you connect your PC, PS3™, Xbox 360®, Wii®, iPod®, DVD player and more. And, the ported, down-firing subwoofer and dedicated bass control help bring your audio to life - and even rattle a few windows.
75 watts (RMS) of power
You've got enough power to fill the room with sound--and even rattle a few windows.
Multiple inputs
You've got the flexibility to set up your system the way you want to. Connect your PC, PS3™, Xbox 360®, Wii®, iPod®, DVD player, and more.
Dedicated bass control
You're in command--dial the bass up or down to for as much (or little) boom as you want.
Ported, down-firing subwoofer
Deep bass brings your music, movies, and games to life.
Surround sound with 3D Stereo
You'll hear it all around you--even from two-channel sources. Your speakers convert two-channel stereo into an immersive surround sound experience.
With most speakers, you need to sit in the sweet spot - usually smack dab in the middle, depending on how you've arranged your system - to get the best sound. Dance around the room or pick a different seat and your audio just won't sound right.
That's because the high and mid frequencies drop out when you move to the side or back of the speaker. (Their shorter wavelengths don't wrap around the speaker like low frequencies.)
Our 360-degree speakers are different. They've got both forward- and backward-firing drivers that project sound more uniformly around the speaker over a wider range of frequencies--not just the low ones. That means the direct and reflected sound are more tonally balanced for a better, more immersive listening experience.
The result? A broad sweet spot that gives you rich, balanced sound in every corner of the room and everywhere in between. So, you can go ahead and make your move.
Works with:
- Computers, music players, TVs, DVD players and other audio sources with 3.5 mm or RCA audio out
- PlayStation®2, PLAYSTATION®3, Xbox 360® or Wii™ using the AV cable that comes with your console
Package Contents
- Speakers
- 3.5 mm and six channel direct audio cables (RCA cable not included)
- Color-coded speaker cables
- User documentation
Technical Specification
Total RMS power:
- 75 watts RMS
- Satellites: 48 watts RMS (2 x 8 W front, 16 W center, 2 x 8 W rear)
- Subwoofer: 27 watts RMS
- Total peak power: 150 watts
- Frequency response: 45 Hz-20 kHz
Cables
- Front: 2 meters
- Rear: 5 meters
- Center: 2.7 meters
- Accessory cables: 2 meters
Subwoofer
System Type
PC multimedia home theatre speaker system
75 Watt
Resources
The following resources are available for the Logitech Z506 5.1 Surround Sound Speakers (75 Watts)
Scroll to top
