BT.com
Wishlist
Logitech Wireless Performance Combo MX800 - Keyboard and mouse set - 2.4 GHz - UK layout
Delivery
Standard Due date unavailable
Laser-etched Incurve keys position your fingers at the optimum comfort level for typing, while you enjoy the smooth, whisper-quiet PerfectStroke typing experience.
The Logitech Unifying receiver is small enough to stay in your USB port when you move around. Plus, you can easily add up to six compatible wireless devices.
What's in the box
  • K800 Keyboard
  • Performance Mouse MX
  • Logitech Unifying receiver
  • Micro-USB charging cable
  • Receiver extender cable
  • User documentation
Logitech Wireless Performance Combo MX800 - keyboard and mouse set - UK
Keyboard and mouse set - wireless
Backlit
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Layout
PerfectStroke, Logitech Incurve keys, Logitech Unifying receiver
Pointing Device
Mouse - laser
Scrolling wheel, 4 programmable buttons, Logitech Darkfield Laser Tracking
3 years warranty
Backlit
2.4 GHz
Wireless Receiver
Input Device
Keyboard
Layout
Pointing Device
Mouse
Movement Detection Technology
Laser
Pointing Device Features
Micro-USB power cable
1 x receiver cable
Microsoft Windows Vista / XP / 7 / 8
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Logitech Performance Combo
Reviewed by Anonymous on 20/11/2014
Excellent well made product.
If you buy the components separately you get 2 USB re-charging leads, when bought as a combo you only receive 1, which means that you cannot re-charge both the keyboard and mouse batteries at the same time.
Otherwise an excellent product
3* Dissapointed
Reviewed by Allan on 02/09/2016
Have had this combo unit for a few weeks now. Keyboard is brilliant no problems there. Mouse unit has poor battery charge, having to charge after a few days. Did try a better battery which did help.Logitech say it should last 30 days. This I think depends on usage. Mouse also stutters at times. Even after changing point settings. Some other reviews say battery life is poor. Consider the cost, I would say not good value for the cost.
Scroll to top
