BT.com
Wishlist
Logitech Wireless Mouse M280 - Black
Delivery
Standard 3-5 working days
Enjoy extra comfort for your right hand through curved grips made of soft rubber. Go longer between battery changes thanks to the energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it.
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking. Plug it once and forget it. Nano receiver gives you a convenient and reliable wireless connectivity.
What's in the box
  • Wireless Mouse M280
  • Nano Receiver
  • 1 AA battery (pre-installed)
  • User documentation
Logitech M280 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
6.79 cm x 10.54 cm x 3.84 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, auto sleep mode, Logitech Advanced Optical Tracking
AA type
Linux Kernel 2.6 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Microsoft Windows Vista / 7 / 8
2 years warranty
Mouse
Wireless Receiver
Orientation
Right-handed
6.79 cm
10.54 cm
3.84 cm
91 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 25 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
1 AA battery
AA type
Run Time (Up To)
18 months
Scroll to top
