Click to visit BT.com
BT.com
Wishlist
Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver
5.0*
Wireless Mouse M235
Quicklinx: 7HSFWS00
Mfr#: 910-002201
Recommended Use: Mobile
Type: Mouse
Wired / Wireless: Wireless
Colour: Quick silver
Compatibility: PC
Express delivery Order within the next 14 hours for delivery tomorrow
39 in stock
£18.54
The feel-good, reliable mouse with more precise navigation and soft rubber grips.
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech® Advanced Optical Tracking
Enjoy precise clicking and pointing--on surfaces other optical mice can't handle--while navigating your favorite websites thanks to Logitech Advanced Optical Tracking.
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
1-year battery life
You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers.
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice--plus a three-year limited hardware warranty.
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
Logitech M235 - mouse - 2.4 GHz - quick silver
Mouse
Wireless - 2.4 GHz
Quick silver
Orientation
Right-handed
Western Europe
Wireless Receiver
Movement Detection Technology
Optical
Scrolling wheel, rubber side grips, battery indicator, on/off power switch
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Orientation
Right-handed
Quick silver
Western Europe
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
Run Time (Up To)
1 year
3 years warranty
Service & Support Details
Limited warranty - 3 years
Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver Bundle deal on Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£28.53
Customer reviews
Write a review for the Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver here!
Best mouse around for laptops.
Reviewed by Ken edwards. Review Posted 24/02/2013
I was given one of these for Christmas, because I was always complaining about the fussiness of my previous laptop mouse with regard to the colour of the surface being used that the mouse wouldn't work on.
It really is fantastic! It will work properly on any surface at all, be it plain, coloured, patterned, or even glass.
The mouse battery can be switched off when not in use, and for transporting the mouse/laptop, the USB bit is placed inside the mouse housing so it won't get lost or damaged.
I would recommend this mouse most definitely for anyone with a laptop, and even as a wireless desktop mouse.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Mouse
Compatibility: PC
Cherry MX Switch Colour: [N/A]
Brand: Logitech
Price Range Inc VAT: 0 - 50
