BT.com
Wishlist
Logitech Wireless Combo MK270 EER Layout US
Logitech Wireless Combo MK270 EER...
£20.62
23 in stock
£20.62
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The reliable wireless combos with a tiny plug-and-forget nano receiver.
Logitech Wireless Combo MK270 - keyboard and mouse set - EER
Keyboard and mouse set - wireless
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Layout
EER
Hot Keys Qty
8
Hot Keys Function
Internet browsing, calculator, e-mail, volume, mute, play/pause
On/off power switch
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
3 years warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
Input Device
Keyboard
Keyboard Name
Logitech Wireless Keyboard K270
Hot Keys Qty
8
Hot Keys Function
Layout
EER
On/off power switch
Pointing Device
Mouse
Pointing Device Name
Logitech Wireless Mouse M185
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
USB extender
Plug and Play
Microsoft Windows Vista / XP / 7 / 8
AA / AAA
Installed Qty
3
Required Qty
3
Alkaline
Limited warranty - 3 years
Buy used stock
What is used stock?
Item condition Customer return - item has been used and shows signs of use
Ref: D08G 039099
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£18.52
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
