BT.com
Wishlist
Logitech Trackman Marble Mouse - Wired USB
Logitech Trackman Marble Mouse -...
£46.45
More than 50 in stock
£46.45
Add to wishlist
Delivery
Standard 3-5 working days
Trackman® Marble®
The Logitech TrackMan Marble gives you superior comfort - for either hand. Ambidextrous design provides long-lasting comfort for right- and left-handed people. Convenient button controls let you easily move forward and backward when you're surfing the Web. Click the large buttons together and use the ball for auto-scrolling. Fingertip-based control enables fast, accurate cursor movements. Patented Marble optical technology ensures smooth tracking.
Left handed? Right handed? When you're working on your computer day and night, and you want more flexibility, the Logitech Trackman Marble will help increase your comfort level.
You'll enjoy all-day comfort with this ambidextrous trackball with convenient button controls.
Ambidextrous trackball design
A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day--whether you use your right or left hand.
Stable base
Your hand stays comfortable all day long with this stay-put design. Plus, it saves you space.
Buttons let you easily move forward and backward when you're surfing the Web.
You'll enjoy fast, accurate cursor movement with just a move of your finger.
Marble® optical technology
Our patented technology gives you smooth tracking on almost any surface so you can be productive wherever you work.
Logitech Trackman Marble - trackball - USB
Trackball
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
4
Logitech Marble optical technology
1 x USB cable - integrated
Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Works with Windows Vista
3 years warranty
Trackball
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
4
1 x USB - 4 pin USB Type A
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM, USB port
Limited warranty - 3 years
Scroll to top
