BT.com
Wishlist
Logitech R400 Wireless Presenter - Remote Control
Logitech R400 Wireless Presenter -...
£43.70
28 in stock
£43.70
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Wireless Presenter R400
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
Logitech Wireless Presenter R400 - presentation remote control
Presentation remote control
Radio
Supported Devices
Personal computer
Max Operating Distance
15 m
Standard - AAA type
Microsoft Certification
Compatible with Windows 7
3 years warranty
Radio
Supported Devices
Personal computer
15 m
Battery level indicator, built-in laser pointer, LED indicator
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista
Carrying case, 2 AAA batteries, wireless receiver
Standard - AAA type
Included Qty
2
Limited warranty - 3 years
Scroll to top
