BT.com
Wishlist
Logitech PTZ Pro Camera
£627.15
£627.15
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Logitech PTZ Pro Camera is a premium USB-enabled HD 1080p PTZ video camera for use in conference rooms, education, health care and other professional video workspaces. The PTZ camera features a wide 90° field of view, 10x lossless full HD zoom, ZEISS optics with autofocus, smooth mechanical 260° pan and 130° tilt, H.264 UVC 1.5 with Scalable Video Coding, remote control, far-end camera control plus multiple presets and camera mounting options for custom installation.
Set-up is a snap with plug-and-play simplicity and a single USB cable-to-host connection. Leading business certifications - Certified for Skype for Business, Optimized for Lync, Skype certified, Cisco Jabber and WebEx compatible - ensure an integrated experience with most business-grade UC applications.
Logitech PTZ Pro Camera - videoconferencing camera
Videoconferencing camera - pan / tilt / zoom
Camera Mount Type
Tripod mount
13 cm x 13 cm x 15 cm
590 g
Wired
Camera
Optical Zoom
10 x
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Video Modes
1080p
Focal Length Control
Motorized zoom
Focus Adjustment
Automatic
Panning Range (degree)
260
Tilting Range (degree)
130
USB 2.0
1 - speaker cable - external - 4.88 m , 1 - video cable - external - 4.88 m , 1 - USB cable - external - 3 m
Full duplex audio, Bluetooth ready, security lock slot (cable lock sold separately), Jabber compatible, WebEx compatible, Skype compatible
Audio Support
Yes : built-in speaker, two-way audio capability, built-in dual stereo microphones
Camera Mount Type
Tripod mount
Wired
13 cm
13 cm
15 cm
590 g
Camera
Colour - pan / tilt / zoom
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Motorized zoom
Optical Zoom
10 x
Focus Adjustment
Automatic
Panning
Range (degree)
260
Titling
Range (degree)
130
Computer Interface
USB 2.0
Remote control, wall/table mount
1 x speaker cable - external - 4.88 m , 1 x video cable - external - 4.88 m , 1 x USB cable - external - 3 m
Plug and Play
Power adapter - external
Google Chrome OS, Apple MacOS X 10.7 or later, Microsoft Windows 7 / Windows 8
System Requirements Details
MacOS X 10.7 or later - Core 2 Duo - 2.4 GHz - RAM 2 GB , Chrome OS - Core 2 Duo - 2.4 GHz - RAM 2 GB , Windows 7/8 - Core 2 Duo - 2.4 GHz - RAM 2 GB
Scroll to top
