BT.com
Wishlist
Logitech PC 960 Stereo Headset USB For Business
Logitech PC 960 Stereo Headset USB...
£24.75
45 in stock
£24.75
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband with volume controls and adjustable boom microphone . The noise-canceling microphone filters unwanted background noise. Ships in a business pack.
Stylish, adjustable over-the-head design for a comfortable fit that won't slip off. Ultra-soft earpad, flexible and lightweight design ensures all-day comfort. USB cable for simple, plug-and-play connectivity. Adjustable boom microphone for precise positioning; the microphone rotates out of the way when not in use. In-line volume or mute controls for easy and precise control. Microphone mute indicator light tells you when mute is enabled. Advanced digital USB delivers superior stereo sound quality. Noise-canceling microphone filters background noise for clearer conversations. White-box business packaging is easy to ship, store and recycle. 3-Year warranty.
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband for all day wear, with in-line controls for volume and mute adjustment. The boom microphone can be adjusted to the optimal position for clearer conversations. The noise-cancelling microphone filters backgound noise, and rotates out of the way when not in use. Ships in a business pack ideal for system builders, integrators and value-added resellers
Logitech PC Headset 960 USB - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Volume, microphone on/mute
3 years warranty
Headset
Recommended Use
Computer
Packaging Type
OEM
Headphones
Supraaural
Dynamic
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
Microphone
Boom
Wired
Sensitivity
-44 dBV/Pascal
Frequency Response
100 - 16000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Headset cable - 2.4 m
Limited warranty - 3 years
Resources
The following resources are available for the Logitech PC 960 Stereo Headset USB For Business
Scroll to top
