BT.com
Wishlist
Logitech MX Performance Laser Mouse - 2.4Ghz USB Wireless Receiver
Darkfield Laser Tracking™ Works Even on Glass Tables!
Delivery
Standard Due date unavailable
Performance Mouse MX?
Laser tracking that works on virtually any surface and a tiny, leave-in wireless receiver put the power to achieve in your hand.
With your Logitech Performance Mouse MX, you've got the power to conquer almost any surface and any task without a second thought.
Logitech® Darkfield Laser Tracking Now, your mouse works where others don't - even on glass. You work and play all over the place--and that means you're going to encounter all sorts of work surfaces. A glass desk or shiny table shouldn't stand in your way. That's why we created Logitech® Darkfield Laser Tracking™, featured in the Logitech® Anywhere Mouse MX™ and the Logitech® Performance Mouse MX™. Darkfield tracks on surfaces like clear glass* and lacquered desks that stump optical mice and standard laser mice. So now your mouse works wherever you do.
It's all in the details.
Optical and traditional laser mice use irregularities in the surface to track the direction and speed of your mouse. The more irregularities on a surface, the easier it is for the sensor to track your movements. But use your mouse on a smooth, glossy surface like clear glass, and there just aren't enough imperfections for your standard mouse to work. This is where Darkfield Laser Tracking comes in. Darkfield uses the smallest possible details to create a micro-road map of the surface--so you get better precision on more surfaces.
Can this mouse do everything?
Just about. Keep in mind, however, that we haven't designed the first two mice with Darkfield Laser Tracking for gamers or for those working on laboratory-grade clean glass. If you're making lightning-fast maneuvers and need gaming-grade cursor speed, take a look at the Logitech® G9x Laser Mouse.
And if you're working on exceptionally clean glass, you may have to wait until the dust settles. For surfaces with fewer than 44 microscopic details (per square millimeter) that are less than 5 µm wide and 1.5 µm thick--to give some context, a strand of human hair is about 100 µm wide--you may want to swipe your hand across the surface before using your mouse. But for everyone else, Darkfield Laser Tracking gives you precise cursor control on virtually any surface--even glass.
You get accurate, precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. Turn the world into your mouse pad
Logitech® Unifying receiver
The tiny receiver stays in your notebook. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers
Flexible recharging system
A micro-USB cable charges your mouse through your computer or a standard outlet--even when in use. You'll always have the power you need to get the job done.
Hyper-fast scrolling
When you need to do some long-distance scrolling, hyper-fast scrolling unleashes the speed demon inside. What's going on under the hood? The ratchet-scrolling mechanism you're used to retracts so the wheel can spin with virtually no friction. Seven seconds. That's how long some of our scroll wheels spin freely--speeding you through hundreds of pages or thousands of rows. And, oh yeah, it's got precision handling too. With normal click-to-click scrolling, you can navigate your lists, slides, and images with the line-by-line control you need.
Sculpted, right-hand shape
Designed to fit your hand and put it in a comfortable, natural position.Comfortable hands like comfortable mice.
Four thumb buttons
Customizable thumb buttons help you do more, faster. Move backward or forward through Web pages, zoom in or out on photos, and jump between open windows.Change the cursor speed? Change the cursor? Change the programmable buttons?
Logitech Performance MX - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Programmable buttons, Logitech Darkfield Laser Tracking
2 x AA type
Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Orientation
Right-handed
Input Device
Wireless
2.4 GHz
Laser
1 x USB - 4 pin USB Type A
Micro-USB cable
AA type
Installed Qty
2
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
Limited warranty - 3 years
Resources
The following resources are available for the Logitech MX Performance Laser Mouse - 2.4Ghz USB Wireless Receiver
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Best mouse in the world
Reviewed by Leon on 23/01/2011
This is the best mouse I have ever used. My last mouse was also the earlier version of this and it was excellent until it started to wear out after a few years. Fully customisable, a button for everything and very comfortable when you are using it for hours at a time. So good that in a few years I will likely be buying it again!
5* Must have mouse for Programmers/Designers
Reviewed by doug on 13/05/2012
This mouse is a joy to use. If you spend 7hrs a day with a mouse in your hand, better make it this one. If you have to navidate up and down 1000 lines of code they you need a mouse wheel that has momentum but when you want to move a line at a time then thats a click away. You want a mouse that works exactly the same on any surface. This has easy access programmable buttons so you jump forward and backwards through code defintions (eg in Visual Studio shift+ctrl + and -)you can quickly flip between application spaces eg Visual Studio and SQL Studio or you can connect in Resharper fuctions.
Basically your productivity shoots up. Sure you could do the same if you are an author, auditor or designer. Sure it gould be greate for gammers to.
Scroll to top
