BT.com
Wishlist
Logitech MK270 Wireless Desktop Kit
Logitech MK270 Wireless Desktop...
£21.91
More than 50 in stock
£21.91
Add to wishlist
Delivery
Standard 3-5 working days
Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range.
Take the mouse with you. This comfortable mouse fits easily into computer bags and pocket to travel with your computer.
A 24-month keyboard and 12-month mouse battery life - plus on/off switches - means you can go for months without the hassle of changing batteries.
Instant access to media controls - movies, music, Internet, e-mail, play/pause, volume and more - are one touch away.
The full-size keyboard with number pad, directional keys, and nine F-keys is comfortable, convenient and built to last.
Logitech Wireless Combo MK270 - keyboard and mouse set - English
Keyboard and mouse set - wireless
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard
Layout
English
Hot Keys Qty
8
Hot Keys Function
Internet browsing, calculator, e-mail, volume, mute, play/pause
On/off power switch
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
3 years warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
Input Device
Keyboard
Keyboard Name
Logitech Wireless Keyboard K270
Hot Keys Qty
8
Hot Keys Function
Layout
English
On/off power switch
Pointing Device
Mouse
Pointing Device Name
Logitech Wireless Mouse M185
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
USB extender
Plug and Play
Included Software
Drivers & Utilities
Microsoft Windows Vista / XP / 7 / 8
AA / AAA
Installed Qty
3
Required Qty
3
Alkaline
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Meh
Reviewed by Anonymous on 05/06/2014
Don't be fooled by the price, this isn't a good deal. The mouse is a child sized device, about half the size of a normal mouse. The keyboard is flimsy, the fold-out feet snap off with the slightest pressure (I've had to glue them back together twice now and I've not had it a week), and the keyboard can't seem to communicate reliably with the receiver if it's more than about 6 inches away - it seems to keep going to sleep and losing connection. Also the keyboard has almost no strength to it whatsoever - you can twist and flex it way beyond what is good for electronics to flex and bend. There are gaping holes in they keyboard too, so you can see through bits of it to the desk underneath. Not really a good solid design at all. Very poor.
Scroll to top
