BT.com
Wishlist
Logitech M345 Wireless Mouse Lime
Delivery
Standard Due date unavailable
The unique-as-you mouse with smooth scrolling. It stands out from the crowd thanks to its unique shape and vivid pops of color. Textured rubber grips make it comfy, too. The precision scroll wheel plus smooth scrolling software makes surfing easier, while Logitech advanced optical tracking gives you precise clicking and pointing on just about any surface without a mouse pad.
The tiny Logitech Unifying receiver stays in your laptop and lets you add up to five more compatible wireless keyboards or mice - without the hassle of multiple USB receivers. And with up to 18 months of battery life, it virtually eliminates the hassle of changing batteries.
Logitech M345 - mouse - 2.4 GHz - wasabi green
Mouse
Wireless - 2.4 GHz
Wasabi green
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel (4-way), on/off power switch, Logitech Unifying receiver
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Wasabi green
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 25 m
Optical
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
Run Time (Up To)
18 months
Limited warranty - 3 years
Scroll to top
