BT.com
Wishlist
Logitech M235 Wireless Mouse Vivid Violet
Delivery
Standard Due date unavailable
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech M235 - 2nd Generation - mouse - 2.4 GHz - vivid violet
Mouse
Wireless - 2.4 GHz
Vivid violet
Orientation
Right and left-handed
5 cm x 9 cm x 3.3 cm
86 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Orientation
5 cm
9 cm
3.3 cm
86 g
Vivid violet
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 25 m
Optical
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
USB 2.0 Full-Speed
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
1 year
Limited warranty - 3 years
Scroll to top
