BT.com
Wishlist
Logitech M100 Mouse - 3 Buttons USB Wired
Logitech M100 Mouse - 3 Buttons USB...
£9.27
16 in stock
£9.27
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Mouse M100
Logitech Mouse M100 gives you just the basics for comfortable, reliable control of your computer. There is no software to install. And since it is corded, you can just plug the cable into a USB port and use it right away. The full-size, ambidextrous shape means your hand will rest comfortably, while high-definition optical tracking (1000 dpi) means you will get responsive, smooth cursor control for precise tracking and easy text selection.
Logitech M100 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.1 cm x 11.2 cm x 3.9 cm
64 g
Western Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Orientation
6.1 cm
11.2 cm
3.9 cm
64 g
Western Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Additional Requirements
USB port
Limited warranty - 3 years
Scroll to top
