BT.com
Wishlist
Logitech Logitech UC Solution for Cisco 725-C
Delivery
Standard Due date unavailable
The UC Keyboard K725-C enables quick voice and video commands right from the desktop using keys that control the headset, call functions, voicemail messages, and other UC features. Illuminated keys display call and video status, and a Plug-and-Play corded design eases use while saving space on the shrinking desktop.
The M525-C wireless mouse designed for Cisco Jabber delivers micro-precise scrolling and comfort for the all-day worker. An ergonomic design with soft rubber grips looks good and feels even better, while advanced optical tracking technology ensures efficient productivity. The included Logitech Unifying receiver also saves space by connecting to a USB port on the keyboard.
The C920-C webcam is designed exclusively for Cisco Jabber to support up to HD 1080p video conferencing. Make a vivid impression with true-to-life, high definition video calls that allow for a 78-degree field of view - no more repositioning the camera to fit everyone in. Multiple mounting options and Plug-and-Play setup ensure ease of use right out of the box.
Logitech UC Solution for Cisco 725-C - keyboard and mouse set - with Logitech C920-C Webcam
Keyboard and mouse set
USB
Input Device
Keyboard
LCD display
Pointing Device
Mouse - optical
Buttons Qty
5
Scrolling wheel, on/off power switch, 1000 dpi resolution, battery indicator
3 years warranty
Bundled with
USB
Dimensions (WxDxH) / Weight
Keyboard: 44.2 cm x 16.2 cm x 3.2 cm / 0.9 kg , Mouse: 10.2 cm x 5.7 cm x 3.9 cm / 122.4 g
Bundled with
Input Device
Keyboard
Keyboard Name
Logitech UC Keyboard K725-C
LCD display
Pointing Device
Mouse
Pointing Device Name
Logitech M525-C Wireless Mouse
Buttons Qty
5
Movement Detection Technology
Optical
Pointing Device Features
1 x USB cable - 2 m
UL, VCCI, C-Tick, GS, CB, FCC, RoHS, KCC, WEEE, GOST-R, TUV T
Limited warranty - 3 years
Scroll to top
