BT.com
Wishlist
Logitech G700s Rechargeable Laser Gaming Mouse - 13 button - wireless/wired - USB, 2.4 GHz
Delivery
Standard Due date unavailable
The game doesn't need to stop when it's time to recharge. G700s charges during play over its standard Micro-USB cable. To power up, switch seamlessly from wireless to data-over-cable connection over a standard Micro-USB cable. The standard AA NiMH batteries charge up while you stay in the game.
Be confident that your every command is executed as quickly as possible. G700s maintains a consistent 1 ms report rate, whether over 2.4 GHz wireless or connected by USB. Up to eight times faster than a standard USB mouse, G700s captures your moves as fast as you can make them.
Logitech Gaming Mouse G700s - mouse - USB, 2.4 GHz
Mouse
Wireless, wired - USB, 2.4 GHz
8.4 cm x 12.9 cm x 4.7 cm
147 g
Movement Detection Technology
Laser
Buttons Qty
13
Movement Resolution
8200 dpi
Performance
30 G maximum acceleration, 12 megapixels per second, realtime sensitivity switching 200 - 8200 dpi, 4.19 metres per second pointer speed
On/off power switch, 3 profiles
1 x USB cable - external - 2 m , 1 x USB extension cable - external
Microsoft Windows Vista / 7 / 8
3 years warranty
Mouse
8.4 cm
12.9 cm
4.7 cm
147 g
Input Device
Wireless, wired
USB, 2.4 GHz
Laser
Buttons Qty
13
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
Scroll to top
