Click to visit BT.com
BT.com
Wishlist
Logitech G700 Laser Gaming Mouse 2.4GHz USB Wireless Receiver 13 Buttons
Wireless Gaming Mouse G700
Quicklinx: 7454WS00
Mfr#: 910-001759
Powerful control that gets you deep into your game. Wireless freedom without performance compromises
No matter what your game, you'll have the control you need to get deep into it. You've got 13 precisely placed, programmable controls to perform single actions and complex macros. With natural curves that support your hand you can play comfortably and maneuver effortlessly for as long as you want. There's nothing to slow you down with full-speed, gaming-grade wireless and a quick-connect charging cable.
13 programmable controls with macro capability
Perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined delays and repeating.
Individually sculpted buttons
Every button on the G700 is carefully designed and placed to be easily identifiable by touch, so they're right there when you need them but out of your way when you don't.
Natural curves that fit your hand
Your mouse is designed to let you play comfortably and maneuver effortlessly for as long as you want.
Smooth gliding feet
You can forget sticky workarounds--the low-friction polytetrafluoroethylene feet glide effortlessly across almost any surface.
Full-speed wireless
1,000 reports per second give you gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
Rechargeable
You'll always have the power you need. A quick-connect cable lets you plug in fast and continue your campaign without pause.
Data over cable
Worried about that critical game situation? Playing in a busy wireless environment? With data over cable you always have a backup for reliable connectivity.
Gaming-grade laser
Game-changing precision at any hand speed. Whether you're zeroing in on one pixel or whipping across a million, the gaming-grade laser gives you hard-to-beat cursor control.
If you're an expert gamer, pixel-perfect tracking can mean the difference between victory and defeat. Our mice with gaming-grade laser sensors can track at speeds all the way up to 5700 dpi. So when the game is on the line, you'll get maximum precision, blinding speed, and ultra-smooth tracking.
Onboard memory profiles
You can program up to five profiles for individual players or games (keyboard macros and dpi settings), so you can play your way on other PCs--without software installation.
Plug-and-Forget Nano-receiver
Take it with you--your Gaming Mouse G700 is laptop ready. The tiny receiver can stay plugged in a USB port or stores inside the mouse for when you head to a LAN party.
Sensitivity switching
You can shift from pixel-precise targeting (200 dpi) to lightning-fast maneuvers (up to 5,700 dpi) in an instant.
Dual-mode scroll wheel
You get precise click-to-click scrolling that's perfect for weapon selection when you're gaming. Hyper-fast scrolling lets you fly through long Web pages.
LED display
Your battery power, profile settings and dpi sensitivity are always visible at a glance--without being covered by your hand.
Ideal for MMORPGs
When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character.
A millimeter. A millisecond. A customizable control right where you need it. The smallest details make all the difference. Never an ordinary device, everything from Logitech G-Series is crafted to perform, to fit you, to feel real. It's the gear that gets you there by getting out of your way. Victory is up to you.
Logitech Gaming Mouse G700 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
13
Movement Resolution
5700 dpi
Performance
12 megapixels per second
1 x USB cable - external
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
13
Movement Resolution
5700 dpi
Performance
1 x USB - 4 pin USB Type A
Software Included
Drivers & Utilities
3 years warranty
Service & Support Details
Limited warranty - 3 years
