BT.com
Wishlist
Logitech Desktop MK120 - Keyboard & Mouse - USB
Logitech Desktop MK120 - Keyboard &...
£14.20
33 in stock
£14.20
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Desktop MK120
Logitech Desktop MK120 is a durable duo that brings comfort, style and simplicity together. You'll be comfortable with the keyboard thanks to the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. With its thin profile, spill-resistant design, durable keys that can withstand up to 10 million keystrokes and sturdy, adjustable tilt legs, this sleek keyboard not only looks and feels good - it's built to last. Plus, it's got easy-to-read keys. The high-definition optical mouse puts comfort and control in your hands with smooth, accurate tracking and a comfortable, ambidextrous shape. And setup is simple - you just plug your keyboard and mouse into USB ports and start using them right out of the box.
With a sleek, comfortable keyboard and high-definition optical mouse, this durable duo brings comfort, style and simplicity together
Comfortable, quiet typing
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Spill-resistant design
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
High-definition optical tracking
You'll enjoy responsive and smooth cursor control with the high-definition optical tracking (1000 dpi).
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits.
Plug-and-play USB connections
Setup is simple--you just plug your keyboard and mouse into USB ports on your desktop, laptop or netbook computer and start using them right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
Sturdy, adjustable tilt legs
You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
Logitech reliability
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
Logitech Desktop MK120 - keyboard and mouse set - English
Keyboard and mouse set
USB
Input Device
Keyboard
Layout
English
Spillproof, tilt legs
Pointing Device
Mouse - optical
Scrolling wheel, 1000 dpi resolution
3 years warranty
USB
Input Device
Keyboard
Layout
English
Pointing Device
Mouse
Movement Detection Technology
Optical
Pointing Device Features
2 x USB cable
Included Software
Drivers & Utilities
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Scroll to top
