BT.com
Wishlist
Logitech B910 HD Webcam OEM MS Lync Optimised
Logitech B910 HD Webcam OEM MS Lync...
£72.84
£72.84
Add to wishlist
Delivery
Standard Due date unavailable
The Logitech B910 HD Webcam, with HD 720p widescreen video calling, stereo sound and top-quality optics with autofocus, is indeed the sharpest way for professionals today to stay connected - without needing to travel.
HD video calling
Users can make true-to-life video calls in fluid, HD 720p video at up to 30 frames per second.
Stereo audio
Coworkers and colleagues will enjoy clear conversations in lifelike, stereo wideband audio thanks to dual mics.
True 16:9 widescreen
The 78-degree wide-angle field of view allows for everyone to be seen during small-group video conferencing.
Carl Zeiss® optics
Managers and specialists alike will enjoy razor-sharp images from a glass lens designed with the help of an industry leader.
Premium autofocus
Images stay razor sharp, even in close-ups (up to 10 cm from the camera lens).
Plug-and-play video calling
Setup is fast and easy on Windows 7®, Windows Vista® and Windows® XP. Just plug it in and it's ready to use with your company's video-calling client.
Certified for Microsoft® OCS
It's certified for Microsoft Office Communicator, so your organization can capitalize on video conferencing and unified communications.
Broad compatibility
Your team can feel confident that this webcam will work with virtually any business video-calling client, including LifeSize® Desktop™.
RightLight™ 2 technology
Even if video calls are made in dim or poorly backlit settings, your webcam will intelligently adjust to produce the best possible image.
RightSound™ technology
Acoustic noise cancellation makes it easier to have a more natural conversation.
Supports silent installation
You can easily deploy and manage the installation of webcams throughout your company with command-line, silent installation.
Manufacturer
Logitech
Model
B910 HD Webcam
Video Input / Camera Type
Web camera
CCTV / Audio Support
Compatibility
PC
System Requirements / OS Required
Microsoft Windows XP SP2 or later
Miscellaneous / Microsoft Certification
Compatible with Windows 7
Video Input / Computer Interface
Hi-Speed USB
Optical Sensor / Total Pixels
5,000,000 pixels
3 years warranty
CCTV / Max Digital Video Resolution
1280 x 720
Packaged Quantity
1
Scroll to top
