BT.com
Wishlist
Loewe Xelos 40" Full HD LED Smart TV
Stunning Spec and Style - With 5 Year Warranty!
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
5 Year Warranty
Discover a world of premium entertainment from Loewe with the 40-inch Xelos. Offering high-end design, Full HD visuals and sleek, contemporary design, it's made to bring you all your media in amazing Loewe quality. You can even watch TV on your terms with easy USB recording.
Key Features
  • Full HD 1080p and 100Hz picture frequency will impress with incredibly sharp motion, perfect for gamers and sports fans. LED backlighting technology adds razor-sharp contrasts. There's even an integrated CI Plus interface for the reception of encoded channels.
  • The Xelos features an integrated Freeview HD tuner which will allow you to watch subscription-free broadcasts. To watch Freeview broadcasts you'll need to check that you can receive it in your area.
  • The Xelos is also a true smart TV. Stream videos and visit sites via ethernet or Wi-Fi (using a dongle, available separately).
  • With two HDMI slots you'll be able to attach satellite receivers, games consoles, home cinema systems or Blu-ray players, helping the Xelos show its true picture quality potential.
  • You'll be able to record directly onto a USB hard drive, leaving you to view the running programme at a later date courtesy of the Timeshift function. Convenient programming is also possible using the clearly laid-out electronic programme guide. If connected to another Loewe TV, everything that you have saved on your hard disk can also be played back on that TV.
  • Discover the new interpretation of classic modernism with premium workmanship, down to the very last detail.
Loewe Xelos 40 40" LED TV
LED-backlit LCD TV
Diagonal Class
40"
Chrome
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Composite, HDMI, S-Video, SCART
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T
Analogue TV Tuner
NTSC, PAL, SECAM
Speaker System
2 speakers
Sound Effects
3D Surround
Stereo Reception System
NICAM
USB
2 ports
Voltage
AC 230V ( 50/60 Hz )
Energy Class
Class B
Power Consumption (On mode)
80 W
Energy Consumption per Year
111 kWh
98.4 cm x 9.7 cm x 64.6 cm
20.5 kg
LED-backlit LCD TV
Energy Class
Class B
80 W
111 kWh
Diagonal Class
40"
Video Interface
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
98.4 cm
9.7 cm
64.6 cm
20.5 kg
Enclosure Colour
Chrome
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Widescreen Modes
Conventional 4:3, Zoom, Panorama, 16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TV Tuner
Analogue TV Tuner
NTSC, PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
NICAM
Digital TV Tuner
Digital TV Tuner
Digital TV Service
HbbTV
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
2
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Sound Effects
3D Surround
Audio Controls
Bass, treble
Speaker System
2 speakers
Output Power / Total
25 Watt
Automatic Volume Control (AVC)
Speakers
2 x main channel speaker - built-in - 12.5 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet radio playback, Internet video playback
Nominal Voltage
Power Consumption Stand by / Sleep
0.17 Watt
Auto On/Off
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent quality buy
Reviewed by Siopaholic on 07/12/2013
The picture on the TV is tremendous, at times like we are viewing in 3D or realtime. The sound is so good we have decided not to get a soundbar. If we were forced to find a negative it would be the slow start up but the quality of picture and sound far outway this. We have other newish Sony smart TVs and tried a few others brands but this is by far the best...bargain at just under £415 delivered...ordering another one today
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Loewe Xelos 40
Item condition Customer return - item has been used and shows signs of use
Ref: 90M6 036208
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£305.04
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
