BT.com
Wishlist
LiteOn iHAS324 - DVD±RW (±R DL) - Serial ATA - internal
LiteOn iHAS324 - DVD±RW (±R DL) -...
£14.58
£14.58
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
A fast reliable SATA DVD writer packed with optical drive technology for accurate disc writing at high speeds. This DVD burner reduces the time it takes to reliably secure your business files, backup your personal files, or create your DVD videos.
SMARTwrite 24x gives fast DVD writing speed and ensures that every disc is burned at its maximum possible speed by learning about the performance of each disc and brand of media. This reduces the time for disc burns and allows some brands of media to be safely burned at higher that their specified speeds.
SATA interface technology increases drive performance by improving data transfer rates and efficiency over older PATA/IDE interfaces. Also featured is SMART-Burn, a Lite-On system that gives you exceptional burn quality by using the optimum writing technique for each disc.
The iHAS324 is a high performance DVD burner, with a fast SATA interface and SMART technology for accuracy, making it an idea DVD burner for your home or business PC.
DVD±RW (±R DL) - internal
Serial ATA
14.5 cm x 17 cm x 4.1 cm
0.9 kg
Optical Storage
DVD±RW (±R DL) - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 24x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.5 cm
17 cm
4.1 cm
0.9 kg
Optical Storage
Read Speed
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, session-at-once, restricted overwrite, random access write, incremental recording, multi-border recording, sequential write, Layer Jump Recording (LJR)
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
Buffer Size
2 MB
SMART Burn
SMART-X, SmartErase, Auto Balance System (ABS), Super AllWrite
Video CD
1 x - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
70,000 hour(s)
Package Type
Retail
Microsoft Windows Vista / 2000 / XP
System Requirements Details
Pentium 4 - 1.3 GHz - RAM: 128 MB - HDD: 650 MB
5 °C
50 °C
15 - 80%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good purchase from BT
Reviewed by Anonymous on 22/03/2017
My last DVD-RW was LiteOn and over 10 years old when it finally failed, not bad in IT hardware years. This one is SATA which my mainboard supports and I was pleased to be free of the bulky parallel (round) cables. SATA cabling does seem a lot tidier and smaller in your PC case. It was recognised in the BIOS (auto), windows loaded a suitable driver when it detected new hardware and its working well under Windows 7 Ultimate x86 with my burning software (Nero and ConvertX) I shopped around for best price before buying. I must say that BT benefitted from the lowest postage costs, even if their item price was slightly higher. Even better, it arrived the very next day and was working within five minutes, unlike many suppliers which take days to despatch. A good purchase from BT and here's to another 10 years of LiteOn with luck.
Scroll to top
