BT.com
Wishlist
LiteOn iHAS324 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA
LiteOn iHAS324 - DVD±RW (±R DL) /...
£13.93
More than 50 in stock
£13.93
Add to wishlist
Delivery
Standard 3-5 working days
A fast reliable SATA DVD writer packed with optical drive technology for accurate disc writing at high speeds. This DVD burner reduces the time it takes to reliably secure your business files, backup your personal files, or create your DVD videos.
SMARTwrite 24x gives fast DVD writing speed and ensures that every disc is burned at its maximum possible speed by learning about the performance of each disc and brand of media. This reduces the time for disc burns and allows some brands of media to be safely burned at higher that their specified speeds.
SATA interface technology increases drive performance by improving data transfer rates and efficiency over older PATA/IDE interfaces. Also featured is SMART-Burn, a Lite-On system that gives you exceptional burn quality by using the optimum writing technique for each disc.
The iHAS324 is a high performance DVD burner, with a fast SATA interface and SMART technology for accuracy, making it an idea DVD burner for your home or business PC.
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.5 cm x 17 cm x 4.1 cm
0.9 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 24x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.5 cm
17 cm
4.1 cm
0.9 kg
Optical Storage
Read Speed
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, session-at-once, restricted overwrite, random access write, incremental recording, multi-border recording, sequential write, Layer Jump Recording (LJR)
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
Buffer Size
2 MB
SMART Burn
SMART-X, SmartErase, Auto Balance System (ABS), Super AllWrite
Video CD
1 x - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
70,000 hour(s)
Package Type
Retail
Microsoft Windows Vista / 2000 / XP
System Requirements Details
Pentium 4 - 1.3 GHz - RAM: 128 MB - HDD: 650 MB
5 °C
50 °C
15 - 80%
LiteOn iHAS324 - DVD±RW (±R DL) / DVD-RAM drive -...
£13.93
Save on this ideal PC Build kit!
Save £16.94
£39.31
Scroll to top
