BT.com
Wishlist
LiteOn 12x Blu-Ray Combo Internal SATA Black
Delivery
Standard Due date unavailable
Bring high definition to your home theater or mini PC with the unique iHES112; a fusion of an exceptional Blu-ray player and convenient DVD/CD burner. With its exclusive airfow system the and short length the iHES112 is the ideal drive for any small PC.
Enjoy an unequaled high-definition Blu-ray movie experience with smooth 12x playback, and ultralow noise operation. Benefit from the drive' s advanced DVD/CD burner function, which includes Lite-On' s SMART technology for reliable disc burns every time. Write to all common DVD or CD formats.
Specially created for easy installation into smaller sized cases and shorter drive bays the drive is a mere 17 cm long. It' s unique airflow design not only makes the drive whisper quiet, and reduces vibration, but also ensures that the drive stays cooler even in confined spaces.
Whether you want to truly experience a Blu-ray movie or simply burn the perfect DVD, add the iHES212 to your mini case for the perfect fit.
Key Features
  • 12 speed Blu-ray system optimized give to the clearest, smoothest playback
  • Unique airflow design channels the air during operation to reduce vibration
  • Short loader design, with a body length of only 17cm
  • Compatible with all common DVD and CD formats
Write Speeds
  • DVD+/-R 16X
  • DVD+/-R DL 8X
  • DVD+RW 8X
  • DVD-RW 6X
  • DVD-RAM 12X
  • DVD-ROM 16X
  • CD-R 48X
  • CD-RW 24X
  • CD-ROM 48X
LiteOn iHES112 - DVD±RW (±R DL) / DVD-RAM / BD-ROM drive - Serial ATA
DVD±RW (±R DL) / DVD-RAM / BD-ROM drive - internal
Serial ATA
14.6 cm x 17 cm x 4.1 cm
0.9 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM / BD-ROM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD) / 12x (BD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Serial ATA
14.6 cm
17 cm
4.1 cm
0.9 kg
Optical Storage
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL
Media Load Type
Tray
Access Time
160 ms (DVD), 150 ms (CD), 380 ms (BD)
Buffer Size
2 MB
SMART Burn
SMART-X
1 x SATA 3Gb/s - 7 pin Serial ATA
Compatible Bays
1 x front accessible - 5.25" x 1/2H
MTBF
60,000 hour(s)
Package Type
Bulk
Microsoft Windows XP SP2, Microsoft Windows Vista / 7
System Requirements Details
Windows XP/Vista/7 - Pentium D - 3 GHz - RAM: 1 GB
5 °C
50 °C
15 - 80% (non-condensing)
Scroll to top
